Date/Time: Thu, 25 Apr 2024 09:45:10 +0000
Forex Data Feed
View Count: 1278
[2014-01-12 06:54:38] |
tobi - Posts: 351 |
You have been working a lot on your new "Sierra Chart Real-Time and Historical Futures Data Feed" lately. Are there any plans to also offer your own "Sierra Chart Real-Time and Historical Forex Data Feed"? Or is the FXCM feed you're using already a top-quality and low latency feed as you would define it? Maybe this is not even possible at all with not having a central exchange in FX!? |
[2014-01-14 07:18:56] |
tobi - Posts: 351 |
[2014-01-17 18:37:20] |
The FXCM feed works reasonably well. Likely we will be adding another Forex data feed by the middle of the year. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-18 00:30:59
[2014-01-18 00:25:58] |
AndyL - Posts: 119 |
The FXCM feed does indeed work well. I stare at charts and my order entry platform pretty much all day and have never observed any big discrepacies or lag. In stark contrast to eSignal, which i have used before and costs well above $100/m. |
