Date/Time: Sat, 20 Apr 2024 05:41:48 +0000
Import tick data file bug
View Count: 990
[2014-01-11 10:54:15] |
TrueBalance - Posts: 4 |
According to the Text/CSV file format description the header is sometimes optional (for instance: "Date, Time, Open, High, Low, Close, Volume"). This is not true as if you don't have the header, SC will skip the first line (tick) in the file. So please either change the doc (make the header line mandatory) or fix the implementation. The doc: http://www.sierrachart.com/index.php?l=doc/doc_TextCSVDataFormat.html It's a minor issue but annoying when you use SC to verify tick data. Regards, TB |
