Date/Time: Thu, 28 Mar 2024 12:21:20 +0000
IMPORT data from csv file
View Count: 1006
[2020-03-23 18:01:53] |
When i import my own data from a csv file , it can be for any timeframe?? Yes.Tick by tick , means , any timeframe for Sierra chart?? 1 second , 30 second , 1 minute.?? Sierra Chart can construct chart bars of any timeframe from tick by tick data.3-Do you have historical data for level 3??(Full depth orderbook). No.
