Date/Time: Fri, 29 Mar 2024 14:41:27 +0000
[User Discussion] - on screen there is 1 signal with 2 orders sent to simulation
View Count: 1047
[2014-01-10 12:39:38] |
ariknoi - Posts: 31 |
but on the orders there are 3 entries and exits so 1 signal but 3 trades. any idea what i did wrong? |
[2014-01-10 16:53:59] |
There are not 2 order fills as you are highlighting in the image. One of the lines is the order update and another line is the fill. This is still just considered one fill.
