Date/Time: Thu, 25 Apr 2024 19:52:49 +0000
Two numbers bars in one study
View Count: 974
[2014-01-10 10:10:01] |
User25186 - Posts: 4 |
Hi I want to use a different color resolution for text and volume numbers in one study. Therefore, I have two numbers bars in the study. The problem is some displacement volume profiles to left side. Do you have any advice? Regards Pavel Date Time Of Last Edit: 2014-01-10 10:18:19
chart2.jpg / V - Attached On 2014-01-10 10:15:45 UTC - Size: 91.05 KB - 369 views Attachment Deleted. Attachment Deleted. chart2.jpg / V - Attached On 2014-01-10 10:15:45 UTC - Size: 91.05 KB - 369 views Attachment Deleted. chart .jpg / V - Attached On 2014-01-10 10:17:53 UTC - Size: 192.26 KB - 382 views Attachment Deleted. chart2.jpg / V - Attached On 2014-01-10 10:15:45 UTC - Size: 91.05 KB - 369 views Attachment Deleted. |
[2014-01-12 18:58:33] |
Not sure how it would work to use 2 instances of the Numbers Bars study and that is not advised. We recommend setting one instance of the Numbers Bars study to display more than one column. Each column can be configured independently. The study supports up to 3 columns. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
