Date/Time: Fri, 29 Mar 2024 02:33:41 +0000
AMP/TTnet with different servers
View Count: 1969
[2014-01-10 08:09:13] |
AKR - Posts: 523 |
I was requesting different server numbers for Europe from AMP for connecting directly to them for EUREX trading (see below). Can I save different configurations for AMP to be able to change connection from the US server (when trading US) to one of the European servers (when trading EUREX)?. Or could you add AMP a second (and third) time to your data feeds with German IP and UK IP preset? Thx! ******************** Germany Public IP : 208.50.27.54 Ports: 10200 United Kingdom Public IP : 208.50.24.54 Ports: 10200 For European based clients connecting to Eurex, please use these IPs in order when configuring Guardian for direct order routing into EUREX. Trade Desk AMP Trading |
[2014-01-12 08:45:06] |
You have the ability to set these IP addresses and the port number through Global Settings >>Data/Trade Service Settings >>Price Feed/Orders >> Server. We will also make these addresses available to AMP if they want to preset them on an account. However your account is not controlled by AMP. You have your own Sierra Chart account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-12 18:13:00
[2014-01-12 08:52:32] |
ganz - Posts: 1048 |
AKR use these IPs in order when configuring Guardian for direct order routing into EUREX.
looks like it is usefull for the native X_Trader only Date Time Of Last Edit: 2014-01-12 08:53:19
[2014-01-12 16:08:26] |
AKR - Posts: 523 |
ganz: well actually had no idea wht "Guardian" meant and had no time yet to try the IP adresses. but thx for your comment. |
[2014-01-12 16:10:22] |
AKR actually had no idea wht "Guardian" meant
I see it and this was the reason to comment "Guardian" - is a part of X_Trader Date Time Of Last Edit: 2014-01-12 16:18:00
[2014-01-12 16:15:14] |
AKR FYI: https://www.tradingtechnologies.com/en/help/guardian/introduction-to-guardian/ |
