Date/Time: Thu, 28 Mar 2024 22:01:43 +0000
Symbol mapping
View Count: 1180
[2014-01-09 21:43:39] |
JohnL - Posts: 27 |
I am not able to get ZB to map with interactive brokers. No SC real-time data feed mapping found for symbol: ZB-201403-ECBOT |
[2014-01-10 10:12:11] |
It has already been set up. Update or Reset the symbol settings as explained here: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings You may also want to update Sierra Chart if you are running an older version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
