Date/Time: Thu, 25 Apr 2024 07:32:31 +0000
chart background color
View Count: 945
[2020-02-11 16:49:38] |
Carol Rutherford - Posts: 66 |
Is it possible to change the background color of one chart? I tried chart, graphic setting, background color and changed the color and hit apply but it didn't change the color of the chart I had highlighted. I've searched and found that under global settings, graphic settings, chart background color that it changes ALL the charts and I'm looking to only highlight one chart. Thanks for any help |
[2020-02-11 16:57:00] |
Ackin - Posts: 1865 |
try this: The first version is opened by selecting Chart >> Graphics Settings on the menu.
This is the chart specific Graphics Settings window and lets you individually set the Colors and Widths for various chart objects for the active chart. And you can set the Chart Text Font for the chart as well. When you use this specific Graphics Settings window, you need to uncheck the Use Global Graphics Settings Instead of These Settings option on this window Graphics Settings: Introduction |
[2020-02-12 15:59:22] |
Yes you can change the color of individual charts. And the documentation is here: Graphics Settings: Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-27 02:18:38] |
User649373 - Posts: 2 |
Hello, The 'apply' button does not work on graphics Settings chart. You have to press 'ok' to validate the change. It is not easy to change the colors this way because you have to click on 'ok' each time and reopen the window. Is this a bug? Version: 2456 Revision: 44232 Thanks. Date Time Of Last Edit: 2022-11-27 02:21:49
Sierra chart - graphical setting.png / V - Attached On 2022-11-27 02:11:21 UTC - Size: 164.51 KB - 67 views Sierra_no_change.jpg / V - Attached On 2022-11-27 02:11:34 UTC - Size: 371.8 KB - 60 views |
[2022-11-27 13:00:30] |
Problem solved in version 2457. Thank you. |
