Date/Time: Sat, 15 Aug 2026 01:15:53 +0000
volume by price
View Count: 1611
| [2014-01-01 23:26:44] |
| User12232 - Posts: 1 |
Hello, is there a tip to plot the same number of horizontal volume bars regardles of the magnitude of the price for the security displayed? For example if I plot the volume profile for the eurusd that trade around 1.38 I get i charts with 15 horizontal volume bars (i set 40 ticks per volume bar). If I use the same setup for the Google stock chart, that trade ove 1000$, the number of horizontal volume bars become infinite. Tks Best regards |
| [2014-01-02 17:22:17] |
Essentially what you are looking for an is an automatic Ticks per Volume Bar setting. This is not supported.
