Date/Time: Thu, 28 Mar 2024 21:46:58 +0000
Bitmex and SC data all services
View Count: 853
[2019-12-12 13:10:54] |
EuropeanTrader - Posts: 290 |
Hi, is it possible for me to connect AND trade a live Bitmex account through my SC instance while I would still be able to browse over "SC Data - All services" symbols and analyze charts of those symbols as well? Thanks. |
[2019-12-12 15:49:49] |
The best way to do this is to install another copy of Sierra Chart. Instructions are on this page: Using Multiple Data and Trading Services at the Same Time Can you tell us what other symbols you would want to look at when using BitMex? We can see about adding those to be used with the BitMex service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-12 15:50:07
[2019-12-13 11:49:33] |
Thanks. XBTUSD is good for now for me.
[2019-12-13 23:41:00] |
But BitMex does already provide market data for that symbol. So we do not understand this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-13 23:41:07
[2022-09-26 14:30:23] |
User435580 - Posts: 3 |
Hi, there are some realtime NASDAQUE Stocks added at Bitmex direct Trading. but is it possible to add the s&p 500 index and the us dollar currency index too? Thanks |
[2022-09-27 09:09:33] |
Sierra_Chart Engineering - Posts: 13610 |
All of the BitMex symbols are available and you can get charts for them and trade them. You just need to get a listing of them and that is explained here: File Menu: Getting Symbols If you need to adjust the settings like Tick Size and Price Display Format that can be done through the Chart Settings: Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-27 09:10:53
[2022-09-30 08:50:05] |
Hi, I apologize for the somewhat imprecise question. in the discussion above you asked EuropeanTrader what other symbols you would want to look at when using BitMex. so, is it possible to add S&P and dollar currency to bitmex? or should i install another copy of Sierra Chart to use this data of these markets simultaneously with xbt? Thank you |
[2022-10-01 09:03:51] |
There is no need for us to add this. You already have access to it. Just follow through the instructions linked in our prior post.
