Date/Time: Thu, 25 Apr 2024 17:11:19 +0000
Candle Price Volume Bars
View Count: 2164
[2019-11-08 18:25:25] |
User178526 - Posts: 4 |
Hello, i would like to use candle price volume bars for my graph draw type. I picked that option, but the bar's aren't getting wider with more volume. Do i need to enable something else? See attached image. Thank you |
[2019-11-10 05:14:22] |
Refer to the documentation for this Graph Draw Type here for complete details: Graph Draw Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-10 05:14:43
[2023-01-20 12:01:46] |
User910035 - Posts: 3 |
Hi, I was trying to change the volume candle width (as per your instruction) and it had no effect. Is this happening because my trial period expired? Currently I don't have an active subscription. thanks for any help. |
