Date/Time: Fri, 19 Apr 2024 11:52:48 +0000
Inter-Market Spread Symbols
View Count: 2724
[2013-04-11 19:35:32] |
We have to add them for you. Can you tell us which specific ones you want and then we will look them up and add them.
[2013-04-11 21:52:42] |
These have now been added. Please restart Sierra Chart and you will see them listed in File >> Find Symbol. For the ZCZW, please follow the instructions here: http://www.sierrachart.com/index.php?l=doc/TradingTechnologies.php#TradingSpreads In the future, you can also add these yourself through Global Settings >> Symbol Settings. You can see how we have added them and you can just do the very same thing. The first 2, are just normal futures contracts symbols. The 3rd one is what is known as a MLEG. And for that one you need to use Get Spread Symbols to actually get the contract data from the FIX Adapter. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
