Date/Time: Sat, 20 Apr 2024 02:26:58 +0000
Copy Chart Drawings from Chart #'s
View Count: 1199
[2013-12-15 10:52:16] |
tobi - Posts: 351 |
Dear SC-Team, would you please consider: 1.) adding a switch (check/uncheck) to turn Copy Chart Drawings from Chart #'s on/off. That way the chart numbers could be left in the box and this function could quickly be turned on/off for the chart as needed. 2.) adding this "switch" to the Customize Keyboard Shortcuts. Thank you! |
[2013-12-19 05:33:48] |
tobi - Posts: 351 |
PLEASE consider adding this suggestion.
[2013-12-29 07:08:13] |
tobi - Posts: 351 |
Have you overlooked this post?
[2013-12-29 07:09:55] |
Yes. We do not have time to take anything new now. We have a lot of critical long-overdue development and this is our focus right now. We do not have time for requests of this category.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-29 07:11:24
[2013-12-29 08:02:07] |
tobi - Posts: 351 |
Ok, I understand that. I thought it's pretty easy/fast for you to do and a little but quite usefriendly improvement in SC.
[2014-01-28 08:22:35] |
tobi - Posts: 351 |
Just in case anyone else looking for this, it can be solved with AutoHotkey.
