Date/Time: Fri, 19 Apr 2024 16:18:40 +0000
Adding OHLC Subgraphs to Number Bars Calculated Values
View Count: 2013
[2019-08-09 23:55:29] |
seandunaway - Posts: 213 |
Hello. Am I able to programmatically add subgraphs to existing studies such as Number Bar Calculated Values? I'm trying to get the bar's O, H, L, C in this incredibly useful study. i <3 sc |
[2019-08-11 09:11:23] |
No, it is not possible to add subgraphs to a study that you did not create/control yourself. With respect to the Numbers Bars Calculated Values study, you can create your own study that creates the same table and just put that into another region. Refer to the following: ACSIL Interface Members - sc.Subgraph Array: Numeric Information Table Graph Draw Type Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-11 09:56:55] |
Very cool! Thank you for taking the time to add this great documentation. A really neat addition to your software would be a "Study Subgraph Data Table" which inputs up to 60 Subgraph References and then draws them as GDT_NUMERIC_INFORMATION. Your software is so powerful, think of all the things we could instantly reference, from Bid & Ask Depth Bars OHLC to our own calculations using the Subgraph math studies. |
the grid.jpg / V - Attached On 2019-08-11 09:56:40 UTC - Size: 185.91 KB - 504 views |
[2019-08-11 13:16:52] |
Ackin - Posts: 1863 |
you can download study for free from our CZ/SK forum (in next update tonight) (just Study in dll file, not code). Study: Tab values contact link: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free Date Time Of Last Edit: 2020-06-24 22:32:27
[2019-08-11 15:03:15] |
Ackin, truly epic :)
[2019-08-12 15:27:57] |
John - SC Support - Posts: 30956 |
Also, refer to the Study Summary Window: Study Summary Window For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-12 23:03:21] |
Thank you John, that is certainly helpful. It's also really nice to see the values develop over time, the picture becomes really clear. (first attached animated gif) Ackin, so cool, thank you! (second attached gif) Sierra Chart, what amazing software you've developed with such thoughtful API to make nearly anything possible, thank you! |
zyp tab values.png / V - Attached On 2019-08-12 23:03:14 UTC - Size: 146.91 KB - 477 views |
