Date/Time: Thu, 25 Apr 2024 17:39:36 +0000
Amount of RAM necessary
View Count: 1578
[2019-08-09 01:24:12] |
It really depends upon what you are doing but in general 4 GB should be enough for the Sierra Chart process itself. But you could end up going more on the 64-bit version. The most important thing though is that you have Sierra Chart running on a dedicated solid-state drive. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-12 13:14:10] |
Nicetas - Posts: 8 |
I recently overclocked my 16gb RAM from 2166 to 2933Mhz experienced this as a huge difference.. I'm using 6 instances of SierraChart on Ryzen 2600 |
