Date/Time: Thu, 28 Mar 2024 15:52:16 +0000
How to display OHLC prices automatically on chart ?
View Count: 2596
[2019-06-13 13:11:20] |
Jean-Francois Benoit - Posts: 3 |
Hi there, I aim at plotting automatically Open/High/Low/Close Price directly at the right side of every bar or candle on a bar/candle chart. I thought SC wonderbox would give me that straight away but I wasn't able to find this feature / study but I can't find it. Thanks for your help. Jeff, from France btw ;-) PS : I hope this will not "not unnecessarily burden Sierra Chart engineers"... |
[2019-06-13 15:52:32] |
Well if we understand you correctly you just want to use the Chart Values tool for this: Chart Drawing Tools: Chart Values/Crosshair Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-13 19:19:35] |
Thank you for your answer, I know the Chart Values tool I look for something different : prices labels plotted at each bar, like the Bar Numbering study but with OHLC prices instead of numbers... I hope I made it clear for you;-) My goal is to see more easily the very differences between prices than only looking at chart, avoid to look at the values in another window or Excel file... |
[2019-06-13 19:40:49] |
Ackin - Posts: 1863 |
direct on bars? Date Time Of Last Edit: 2020-06-24 22:28:06
[2019-06-13 21:10:09] |
Very kind of you M. Ackin ;-) Thks, I tried the moving averages but missed the "Value of subgraph" as draw style, well done ! Do you use it for yourself ? |
[2019-06-13 21:16:11] |
No, I do not, the idea just for youIf you want is possible download it for free from our CZ/SK forum. Study: OHLC text (without moving average and with offset) contact link: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free Date Time Of Last Edit: 2020-06-24 22:27:55
