Date/Time: Wed, 24 Apr 2024 00:15:22 +0000
Chartbook format backward compatibility
View Count: 1211
[2013-11-26 14:24:40] |
Are there any error messages displayed in the Window >> Show/Hide Message Log when you open the Chartbook? What version do you want to go back to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-11-26 14:25:34
[2013-11-27 03:27:54] |
You are not going to be able to use a Chartbook which is giving that error in version 937. You will have to use one of the backup Chartbooks: http://www.sierrachart.com/index.php?l=doc/doc_Chartbooks.html#BackupChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
