Date/Time: Tue, 23 Apr 2024 22:12:27 +0000
Volume indicator
View Count: 2741
[2013-04-10 12:31:06] |
User23815 - Posts: 209 |
New user. I use a standard volume indicator on the bottom of a 60 min chart. It does not draw a volume bar on every price bar. I also have 15 min chart with volume indicator. It shows bars in reduced chart size, but if I maximize chart it then only shows some periods. The time that show when others are missing varies. I don't believe I changed any settings other than color when I added the study. Trading currency futures.
[2013-04-10 16:48:00] |
Check the Study Subgraph color settings to make sure all of the colors are not the same as the background color. Refer to this page: http://www.sierrachart.com/index.php?l=doc/helpdetails9.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-10 17:16:45] |
Those seem fine. Black background, blue bars. It appears to be in the values setting of the study. Possibly the scale or the value format. Format set to 1. I had horizontal grid on in the area but unchecked it on chart settings. Volume on data panel drops to 4 digit as it disappears, shows as we move to 5 or 6 digit.
[2013-04-10 17:22:01] |
Post an image of the chart following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-10 17:23:35] |
It appears as if I am getting huge spikes in the volume. Hourly volume even during London session of currency futures is 4 to 5 figures. Then will spike to 7 or more for the hours that the bar shows. On closer look there are little dots at the margin, meaning very small bars reflecting the huge difference in the reading. I don't believe on an hourly basis that is correct. Feed is from IB.
[2013-04-10 17:30:52] |
Uncheck Global Settings >> Data/Trade Service Settings >> More Interactive Brokers Settings >> Simulate Trades to Match Daily Volume.
