Date/Time: Thu, 18 Apr 2024 15:18:48 +0000
symbols for historical data chart
View Count: 1168
[2013-11-14 16:28:31] |
User42397 - Posts: 19 |
Why is it that when I enter es#.dly on the historical data chart, the historical data chart comes up, but when I enter ct#.dly for cotton, or he#.dly for lean hogs, I get a download failure? Am I using the wrong symbols? I was using those I accessed off of what I thought was the correct page in the help section. Perhaps you can advise. Also, why, when I pull up the historical data chart for ng#.dly (natural gas), does the chart go from 1990 to only May 10, 2013? I can;t get it to go beyond that date. Thank you. |
[2013-11-14 18:36:37] |
There should not be a problem with this. Restart Sierra Chart and open one of those charts again and provide us a copy of the Message Log, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
