Date/Time: Fri, 29 Mar 2024 23:50:45 +0000
Detach chart values for tool window.
View Count: 1153
[2013-11-13 22:21:52] |
irasna - Posts: 5 |
new issue now,I am using version 1040. Chart values for tools window now always stays on top.while detach/attach option is not highlighted.So it does not give the option of getting this in the background. I have tried doing it myself.could not do it ,that is why sending you this e mail for help. |
[2013-11-14 22:02:50] |
The Chart Values window is always going to be on top of the main Sierra Chart window when you are working with the main Sierra Chart window. If you detach a chart and then go to that chart, that the Chart Values window will switch to be associated with that chart and be on top of that chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
