Date/Time: Thu, 25 Apr 2024 23:08:10 +0000
Condition in Alert not working
View Count: 1198
[2013-11-13 20:42:28] |
nepher - Posts: 56 |
Hello, I built an alert that triggers when the close is nearer of the High than the Low of the candle : I use Range bar chart, the following syntax works perfectly : AND(H-C<C-L) but I need to include equidistance so AND(H-C<=C-L), it doesn't work. Moreover AND(H-C=C-L) or AND(C>(H-L)/2) don't work too, Some ideas please ? Thanks for your tips. Axel |
[2013-11-13 20:57:04] |
Check the Value Format setting: http://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html#ValueFormat Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
