Date/Time: Fri, 29 Mar 2024 06:02:03 +0000
5 second candelstick charts for e mini S&P 500
View Count: 1211
[2019-02-03 21:15:18] |
Yes this is fully supported. Refer to: Changing Chart Bars Period You can create charts all the way down to 1 Tick. Sierra Chart is a very powerful charting and trading program with lots of features and flexibility. You can create chart bars of any timeframe including variable time frames. That is one advantage. Do you work with Robinhood or Firstrade? No but if you use the supported Interactive Brokers trading service you should get good commission rates for stock trading. You could have a look at them.:https://www.sierrachart.com/index.php?page=InteractiveBrokers.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-03 21:15:44
[2019-02-04 19:19:13] |
As a practical matter your location is going to be largely irrelevant if not completely. There are so many other factors which are more relevant which you are not even aware of. So are you going to be trading futures? There's no such thing as commission free with futures. There are always going to be at the very least exchange fees that have to be paid per contract. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-05 04:19:59] |
There are other things we are not aware of. There are all kinds of issues on the network and Trading gateway provider which can delay an order and make the network latency largely irrelevant, that neither of us are aware of. Unless you are connected to a trading gateway which is dedicated for your own use and has assured low latency there are just simply no guarantees of speed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-05 04:20:49
