Date/Time: Thu, 28 Mar 2024 08:32:51 +0000
Can we change the default column settings in spreadsheet?
View Count: 1223
[2013-11-13 03:05:54] |
4646ed - Posts: 230 |
The default setting in the spreadsheet for system/alert is 16 columns.I try to reduce to 4-6 but it resets to 16. Any way to change it?
[2013-11-13 03:21:10] |
Sawtooth - Posts: 3952 |
16 is the minimum, 60 is the maximum
[2013-11-13 03:31:53] |
16 is the minimum.
[2013-11-14 16:47:56] |
So, to clarify, the answer is No? can't change the minimum?
[2013-11-14 18:43:54] |
No.
