Date/Time: Thu, 28 Mar 2024 22:16:34 +0000
Historical daily chart?
View Count: 2340
[2013-04-08 13:25:59] |
M5amhan - Posts: 468 |
Hello Since I updated to 961 this weekend, I noticed something this morning about my daily bars. The opens are very random, Im not sure where they are coming from. Can you explain this to me? In the attached picture the cursor is on the sunday night comex open vertical, and daily chart bar open horizontal. It is like this on every symbol. Also does it still plot the close at settlement? Thanks for reading |
[2013-04-08 15:36:40] |
here is the same chart again.. i deleted and downloaded the data and getting a new random open, all the symbols are doing this i have also attached another chart from my other platform to show what it should look like Date Time Of Last Edit: 2013-04-08 15:56:56
[2013-04-08 18:04:22] |
It looks OK for us: http://www.sierrachart.com/image.php?l=1365444229767.png Not sure why there would be an issue in your case. See if it is OK tomorrow. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-08 18:06:45] |
Something must have clicked, I kept hitting delete and download every so often and it finally corrected itself. Thought you might have done something. Anyway, if it keeps on I will just reply to this post. Thanks |
