Date/Time: Wed, 24 Apr 2024 08:46:40 +0000
Numbers Bars and autoscrolling
View Count: 2565
[2013-04-08 08:47:54] |
FGBL07 - Posts: 19 |
I use a Constant Volume Bar Chart with Numbers Bars v2. Pullback column is enabled. When a new bar is painted the chart does not scroll properly, the Pullback column is only shown halfway. Besides the chart loses the scrollbar (only way to scroll it, so the Pullback column is displayed properly) though the menu item is checked. Unchecking and checking the menu item again restores it. I use version 961 but this happened already in 954. Thought an upgrade would help. Windows 7 home premium 64-bit. Date Time Of Last Edit: 2013-04-08 08:48:28
SNAG- 08.04.2013 10.39.13.png / V - Attached On 2013-04-08 08:47:43 UTC - Size: 57.94 KB - 752 views |
[2013-04-08 08:54:30] |
Never heard of a case where a chart loses the scrollbar unless you deliberately disable the scrollbar or the chart is not active and you have enabled General Settings >>Auto Hide Chart Title bars and Scrollbars. We also ourselves never observed such a case where a chart loses a scrollbar or could see how that would happen other than for the reasons given. Aside from this, you just need to add some fill space to the right side of the chart and lock the fill space with Chart >> Lock Fill Space. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-08 08:58:13
