Date/Time: Fri, 29 Mar 2024 13:59:15 +0000
[Locked] - Drawdown issue
View Count: 704
[2018-09-08 02:00:05] |
As the documentation explains here those calculations fully rely on the High During Position and Low During Position fields: https://www.sierrachart.com/index.php?page=doc/TradeActivityLog.php#NotesAboutRunupDrawdownMaximumOpenPositionPLEfficiencyFields You can see these on the Trade Activity tab. Your image shows older fills. There can be various reasons why those values are not accurate or 0. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-08 02:00:46
[2018-09-09 21:58:23] |
We see you are using Flat to Flat. We cannot reproduce the issue but does not surprise us either that there could potentially be a problem with that. This was worked on by another programmer who is no longer with us and we plan to completely redevelop this functionality which will resolve the issue. We have not been happy with with the internal implementation in some areas. We will be re-implementing many aspects of the trades list including these runup and drawdown calculations and high/low values during position tracking for trades. Also, part of this is to remove Flat to Flat and implement these as separate fields. We are going to do our best to get started on this. We can probably start this week but probably the flat to flat fields will need to be done later. So at this point just please wait until this is done. We will not comment on this further and this thread is locked. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-10 22:06:56
[2018-09-10 22:07:06] |
We plan to get started on this, this week. Probably today.
