Date/Time: Fri, 29 Mar 2024 12:30:53 +0000
ZB futures range chart issues
View Count: 2726
[2013-04-07 01:42:21] |
FFTrader - Posts: 180 |
The futures contract is ZBM13. This is a 64 ticks range chart: http://www.sierrachart.com/image.php?l=136529869377.png This is a 94 ticks range chart: http://www.sierrachart.com/image.php?l=1365298732930.png You noticed the charts are IDENTICAL!? In fact, any settings larger than 50 ticks or so, the charts looks exactly the same as the 51 ticks range chart. What is going on or can this issue be fixed with the next update. Other futures contracts (e.g. GC, ES, CL, etc.) that I look at do NOT have this issue. Date Time Of Last Edit: 2013-04-07 01:46:38
[2013-04-07 02:05:16] |
A new trading session has begun and you have New Bar at Session Start enabled in Chart >> Chart Settings. This will cause the current range bar to be stopped and the new one will begin. This is something to be aware of.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-07 02:05:39
[2013-04-07 06:04:16] |
Thank you!
