Date/Time: Fri, 19 Apr 2024 23:24:40 +0000
Question Regarding TPO profile Chart and Initial Balance 1 and 2 Line
View Count: 2018
[2013-10-17 03:10:32] |
User46099 - Posts: 2 |
Hi, How can I change the TPO study so that the "Initial Balance Line 1 Above and Below" (Yellow Line in pic) and "Initial Balance Line 2 Above and Below"(Red Line in pic) show up on the left side of the chart vertically instead of horizontally. http://www.sierrachart.com/image.php?l=1381979325991.png Thank you for your help. |
[2013-10-18 19:43:09] |
This is going to be reviewed over the weekend. We need to spend some further time to look at this more closely. So you are looking for a separate vertical line which shows the initial balance range extended by a certain percentage? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-19 19:39:41] |
Yes, a Vertical line instead of a horizontal line which show the Initial balance range extended. Thank you. |
[2013-10-22 01:58:01] |
As you can see in this image, it is possible to extend the initial balance range by the specified percentage: http://www.sierrachart.com/image.php?l=1382406931914.png This has a separate color. This is the "Extend Initial Balance Range By %" study input. For additional extensions which are colored separately and as a separate vertical line, we will see about that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-22 17:26:27] |
emp0804 - Posts: 31 |
It would be great to have 3 extensions of the initial balance colored differently in the same vertical line.
[2014-02-19 04:09:27] |
Support, Any status on: For additional extensions which are colored separately and as a separate vertical line, we will see about that. Date Time Of Last Edit: 2014-02-19 04:09:59
