Date/Time: Fri, 29 Mar 2024 13:20:06 +0000
Sierra tick data for DOM and orderflow
View Count: 1118
[2018-07-03 20:38:39] |
No. You have to pay for that. You have to go through the procedures and rules established by the exchange. Refer to: Is Historical and Real-time Futures Data Included? You will want to use this data feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-03 20:38:53
