Date/Time: Fri, 19 Apr 2024 02:20:15 +0000
Routine Backups
View Count: 2797
[2013-04-05 23:33:47] |
User23815 - Posts: 209 |
New user. Is there a backup routine in the program? I want to weekly backup my settings so that I can get up and running quickly in case of a crash. If no backup routine, what is recommended? thanks
[2013-04-06 04:14:16] |
You just need to use a backup program to backup the folder that Sierra Chart is installed to. The default is C:\SierraChart
[2013-04-06 14:04:54] |
SgtJ - Posts: 154 |
I highly recommend this backup software. I use v.11 fwiw http://www.cobiansoft.com/cobianbackup.htm |
