Date/Time: Thu, 25 Apr 2024 12:12:58 +0000
Placing orders on BitMex
View Count: 672
[2018-06-11 17:19:47] |
Those orders for different accounts need to be done separately. The ability to support multiple accounts is considered an upcoming feature but it will be a while before that is going to be supported. Also at the present time to use multiple BitMex accounts requires separate installations of Sierra Chart. Refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-11 17:20:00
