Date/Time: Sat, 20 Apr 2024 13:39:15 +0000
Data Bars Lag WHEN CountDownTimer goes NEGATIVE [on tic and Volume charts]
View Count: 1246
[2018-03-09 18:54:45] |
Refer to the documentation for the Countdown Timer study about this: Countdown Timer And make sure your computer's clock is set correctly: http://www.sierrachart.com/index.php?page=doc/helpdetails38.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-15 18:28:47] |
Follow the instructions here to set Sierra Chart for a tick by tick data configuration: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
