Date/Time: Thu, 28 Mar 2024 20:23:34 +0000
message log .I have this message to version 1026
View Count: 1256
[2013-09-23 17:38:14] |
salsem - Posts: 43 |
Hi Support SC, I have this message to version 1026 Version 1026 SC /TT message loge : HttpSendRequest failed: Windows error code 2: Can not find the file specified. | 2013-09-23 13:23:20 Thanks in advance |
[2013-09-23 20:20:37] |
Sierra Chart - Max - Posts: 5554 |
From: http://www.sierrachart.com/index.php?l=doc/LoginInstructions.php#LoginProblems 2.2. Internet Explorer Set To Work Off-line: Make sure Internet Explorer is not set to Work Offline. When this is true, it is clearly stated on the Internet Explorer title bar. If Internet Explorer is set to work offline, select File >> Work Offline on the Internet Explorer menu, and make sure it is not checked. An indication that you are encountering this issue is that you will receive an error like this: HttpSendRequest failed: Windows error code 2.
Sierra Chart Support Date Time Of Last Edit: 2013-09-23 20:20:59
