Date/Time: Fri, 29 Mar 2024 09:24:28 +0000
Bitmex overriding/cancelling orders?
View Count: 2888
[2018-01-22 20:05:48] |
Your first question you need to ask BitMEX about this. In regards to Stop-Limit Orders, these are supported. Refer to: Order Types: Stop-Limit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-02 12:08:07] |
User564539 - Posts: 27 |
Same applies to me, Bitmex is cancelling new orders when entering a new position its just frustrating. The reduce option is not ticked and applies to limit orders but I am sending market order. I also noticed on logs that on logs timeinforce = immediate or cancel but trade window is showing goodtillcancel. Simulation mode works fine all positions are entered and exited successfully. |
[2019-02-03 02:56:41] |
I also noticed on logs that on logs timeinforce = immediate or cancel but trade window is showing goodtillcancel. Make sure you are looking at the correct Trade Window:Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-11 08:53:45] |
I have attached the correct window, but this is the response i got from Bitmex and the image attached for reference Sorry for the delay in getting back to you. The Engine Team have investigated and found that this order was cancelled because it was a close order and there was no open position. It appears that the order that filled right before it, 8a0c2ba, closed out the position. Regards, Chad BitMEX |
Attachment Deleted. |
[2019-02-11 23:23:23] |
Have a look at these options: https://www.sierrachart.com/index.php?page=doc/BitMEX_Trading.php#SettingOrderExecutionInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
