Date/Time: Fri, 19 Apr 2024 14:55:23 +0000
OTC Symbol for IB
View Count: 1038
[2018-01-15 04:03:33] |
Refer to the stock symbol format here: Interactive Brokers Symbols: Stock Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-19 18:44:10] |
In TWS, what does it show as the exchange for this symbol? We need the particular exchange code.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-19 18:44:24
