Date/Time: Wed, 29 Jun 2022 00:47:30 +0000
Bad data streaming
View Count: 726
[2013-09-19 12:44:47] |
roman06 - Posts: 9 |
Hello, I am not able to stream all my data in sierracharts. If I have only few charts its ok, but after I put there about 20-30 charts, some of them are not streaming real time data. How can I be able to stream it real time? Please do not tell me this is a problem with my data provider, my data works 100% all the time. Thank you. Roman |
[2013-09-19 16:38:27] |
If you are using OEC, then this is a limitation of OEC. Please see this section: http://www.sierrachart.com/index.php?l=doc/openecry.php#Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
