Date/Time: Thu, 25 Apr 2024 03:35:20 +0000
Decimal drop off on ES price in chart
View Count: 1344
[2013-09-17 16:44:08] |
User31737 - Posts: 73 |
just updated to version 1025. I use CTS and applied the FIX updates as directed. The issue I am seeing is the Zig Zag study is not displaying the full price for the ES.CME contract. I have Display Reversal Price Yes and Display length of ZigZag line checked Yes, and they both omit the last two digits after the decimal and the price is being rounded. Example: price of the ES at the last Zig reversal price is 1695.50, and it is displayed as 1696. The length of the line is 2.25, it is displayed round down as 2. How do I fix this? edit - the decimal is correctly displayed in the scale margin Date Time Of Last Edit: 2013-09-17 16:50:27
[2013-09-17 16:54:33] |
You need to adjust the Value Format to the Study Settings window for that study: http://www.sierrachart.com/index.php?l=doc/helpdetails32.html#StudyOnTheChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
