Date/Time: Fri, 19 Apr 2024 06:04:13 +0000
Rithmic data feed still disconnecting-Live trades executed within last 15days
View Count: 1335
[2013-09-17 12:07:11] |
User57124 - Posts: 48 |
I use Sierra for charting another platform for trades, I was informed in last support help to update to Sierra software which i did, but Im still having to reconnect and I have done live trades with Rithmic within the last 15 days 15 or more...What do i have to do to fix this Rithmic Sierra staying connected issue thx R |
[2013-09-19 00:40:34] |
Checking on this now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-19 00:44:31] |
We see that you are using a newer version and we have verified that external order fills received do count as trading. So we are not sure what the issue is. Apparently the order fills are not being received by Sierra Chart. What we recommend is entering an order away from the market and canceling it to prevent the disconnections. Here are the instructions for this: https://www.sierrachart.com/index.php?l=doc/Rithmic.php#TradingRequirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-19 00:45:02
