Date/Time: Wed, 24 Apr 2024 16:09:30 +0000
BITMEX BCH Futures DOM messed up
View Count: 2536
[2017-11-23 20:13:11] |
User891094 - Posts: 11 |
Prices and Size has nothing to do with actual reality. Can you please have a look into it? |
[2017-11-23 20:41:41] |
Look at the same symbol on the BitMEX website and if you see an ongoing difference between what Sierra Chart shows and the BitMEX website in regards to market depth data, then provide an image the market depth data in Sierra Chart and another one from the BitMEX website at the same time.
[2017-11-23 20:54:22] |
Ok...thanks for the advice...it's not that I haven't done this yet. I made you another screenshot. Can you just have a look at the Bitmex site and the SC - DOM? Thanks for the great support. |
BCH again.jpg / V - Attached On 2017-11-23 20:53:07 UTC - Size: 98.76 KB - 438 views |
[2017-11-24 18:30:26] |
We will solve this.
