Date/Time: Thu, 18 Apr 2024 02:39:47 +0000
Chart Trade Mode
View Count: 1145
[2013-09-11 13:18:37] |
joshtrader - Posts: 438 |
1. Global Settings -> Customize Chart Trade Menu 2. Trade -> Chart Trade Mode On Right click on the chart, and you will see the commands you specified in step 1. Study carefully the menu items on the Trade menu. I would suggest to turn on Trade Simulation Mode and play around with some of this to get a feel for it. Date Time Of Last Edit: 2013-09-11 13:19:20
[2013-09-11 22:40:20] |
Refer to: http://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
