Date/Time: Wed, 19 Aug 2026 23:37:58 +0000
[User Discussion] - Linux
View Count: 118564
[2026-07-02 12:30:57]
mikrom - Posts: 9
Just moved my Sierra Chart installation from windows to linux (bazzite distro). I'm amazed by how well it works.
The only issue I have is with OpenGL enabled, it still gives me blank charts even after the regedit trick. Maybe because I'm using wayland? If anybody got openGL working with wayland and a modern nvidia GPU, please let me know. I've tried various wine versions from 8 to 11+.
[2026-07-04 13:42:24]
ertrader - Posts: 698
Good to hear the linux experience! In the comments above you can see the OpenGl issues I've had. I uncheck OpenGL now per SC's feedback and all is working. I'm not using wayland however.
[2026-07-07 04:55:57]
allons_trading - Posts: 50
Currently running Wine 11.3, OpenGL enabled on both instances. Anything past 11.3, charts won't display. Also not running Wayland.
[2026-07-07 15:06:57]
R1sk - Posts: 259
When I select Chart Data Type: "Historical Chart," for last about 7 years I get the following errors in the log:
2026-07-07 17:51:28.578 | File compression not supported on file system. C:\SierraChart\Data\F.US.MESU20.dly. Windows error code 50: Request not supported. | Number times message added: 4
2026-07-07 17:51:28.588 | File compression not supported on file system. C:\SierraChart\Data\F.US.MESZ20.dly. Windows error code 50: Request not supported. | Number times message added: 4
2026-07-07 17:51:28.597 | File compression not supported on file system. C:\SierraChart\Data\F.US.MESH21.dly. Windows error code 50: Request not supported. | Number times message added: 4
. (30 rows of them)
2026-07-07 17:51:28.738 | File compression not supported on file system. C:\SierraChart\Data\F.US.MESU26.dly. Windows error code 50: Request not supported.
The chart works fine, so this isn't anything critical but it would be nice to be able to turn off those messages, as they unnecessarily clutter the log.
Any ideas how to do it?
Date Time Of Last Edit: 2026-07-07 15:08:00
[2026-07-07 15:40:24]
mikrom - Posts: 9
@R1sk Go to Global Settings >> Advanced Service Settings, set these to No
Support Intraday and Market Depth Files Compression
Disable Intraday and Market Depth File Compression if Enabled on the File
[2026-07-18 07:05:38]
R1sk - Posts: 259
@mikrom That helped. Thank you.
