Date/Time: Wed, 13 May 2026 12:51:51 +0000
[User Discussion] - Linux
View Count: 110963
[2025-09-29 00:18:01]
Tony - Posts: 715
@gtaranti,
Which distro are you using?
Couple of thoughts,
1, I think Bottles are totally unnecessarily, since Wine already works flawlessly.
2, I am using Linux Mint, under Date & Time settings, I always turn 'Network time' on, so, I won't have accuracy issues.
[2025-09-29 05:59:34]
gtaranti - Posts: 99
@Tony,
I'm using Bluefin.
1. I'll try Wine but Bottles adds some enhancements.
2. I also have 'Automatic Date & Time' which supposedly synchronizes with internet time.
Also this '6 secs off' I doubt it's true.
[2025-09-29 15:22:33]
Tony - Posts: 715
hey gtaranti,
yeah, 6 seconds is a big deal, especially when market is volatile, I would try use USA server instead of European server 1st, or simply disable NTP client.
What I am doing right now is writing a ACSIL study to monitor any discrepancy between last price and computer time, if the difference is more than 1 second, I will get a warning:
  // other code
  int SecondsDelayed {
    sc.IsReplayRunning() ? 0 :
    (sc.CurrentSystemDateTime - sc.BaseDataEndDateTime[sc.Index]).GetTimeInSeconds()
  if (SecondsDelayed >= 2)
    // warning message on screen
  // other code
Date Time Of Last Edit: 2025-09-29 15:24:26
[2025-10-26 20:19:39]
ertrader - Posts: 697
Quick update...I've not seen any issues from a wine perspective with sierrachart. I've been on wine 10.0 and not on the development releases. I have updated to the latest mint linux. Had some kernel update issues but they were resolved.
Latest configuration:
SierraChart Version 2803 64 bit (2 instances)
Wine 10.0
Mint Linux 22.2/Cinnamon desktop
Kernel 6.14.0-32 generic
AMD Ryzen 7 3800X
GeForce GTX 1660 Nvidia/6 GB GDDR5/Driver 545.29.06/OpenGL
Dual Monitors 1920X1080 60 Hz for both monitors
Total System RAM: 16 Gig
Memory usage: <500 Meg for main instance 200 meg for copy trade instance. This configuration greatly simplified my setup.
CPU Utilization: <8% for main instance <5% for copy instance.
28 Charts, 4 instruments and 4 ADR symbols (ES, YM, NQ, RTY, ADR-YM, ADR-TF, ADR-NASDAQ, ADR-SP)
Denali data-feed with MBO data
Teton Order Routing with Stage5/Advantage and Ironbeam
Rithmic for trader evaluations and PA accounts
RealVNC for remote access
Updated 10/26/25
Date Time Of Last Edit: 2025-10-26 20:20:24
[2025-10-28 00:55:03]
User303857 - Posts: 186
Does anybody know how to get the sierra zip downloader to load into all the files in the correct file path?
What is used in place of C:\SierraChart ?
I am new to Linux, downloaded and installed Cinnamon & Wine & the sierra zip installer into the downloads folder.
Not sure how to get it installed & running.
for any help
[2025-10-28 16:40:46]
User687917 - Posts: 84
@User303857 post #779
SierraChart is a portable program.
On Linux, with Wine installed, you would simply run the installer's .exe file.
If you choose the ZIP version [Software Download: Zip Installer Detailed Instructions], create a folder, for example, in the path /home/myuser/SierraChart or in the path of your choice, and extract the contents of the ZIP file there.
Then simply run “SierraChart.exe” and the program will run with your default Wine settings.
If you want more settings, for example for the theme to use, I prefer to install SierraChart using Winetricks, in an isolated “Wineprefix”, and there I configure a dark theme just for the platform.
[2025-11-13 04:42:13]
allons_trading - Posts: 47
Finally decided to build up a new PC as I was tired of dealing with the really random, non-reproducible laptop crashes.
Installed CachyOS on this PC vs Manjaro on the laptop.
AMD Ryzen 9 9950X
64GB of memory
2TB NVME Gen 5 + 2TB NVME Gen 4
AMD Radeon 9070XT
2 32" 1440p monitors
CachyOS
Wine 10.18
I run two instance of SC with each instance consuming 40-60% CPU usage with OpenGL enabled on the laptop for the chartbooks I currently run.
The fans on the laptop would run constantly.
The only issue I have, which may not be an issue after all, is that I am currently unable to get SierraChart to keep OpenGL enabled on 10.18. I had
already opened a bug on Wine for >10.9 as all the chart windows would be blank with OpenGL enabled.
After moving over the NVME drive and starting up the chartbooks, each instance of SierraChart is currently sitting at < 1% CPU usage. Zero issues
scrolling charts, which was the big reason for running with OpenGL on the laptop.
[2025-11-16 01:00:37]
methodtrades - Posts: 48
If you ever learn a fix to that opengl black chart issue @allons_trading please report back!
[2025-11-20 00:27:54]
Deiter - Posts: 14
I recently moved from Windows (I've been on DOS/Windows since the 80s) to Arch Linux. I just couldn't stand the Windows enshittification any more. The only reason I boot Win11 anymore is to run Sierra Chart native for an hour or so during RTH, since my trading style is very short-term and dependent on DOM, pullback columns, T&S, etc. and I want as few impediments to I/O as possible.
Though I'm on Arch Linux now, I understand the SC team's frustration with all the major operating systems. I hope they just bypass major OS altogether and create a homegrown trading technology stack that needs to live on its own SSD. Perhaps add support for one or two web browser families (Chrome and friends, Firefox), and leave the Win/Mac/Unix madness behind. I certainly understand the pain of supporting all the different use cases out there, but perhaps taking the SC community in the direction of a custom, minimalist OS is the right path.
Regardless, I will keep using SC. It is truly one of the few sane bits of complex software out there.
Happy Trading and Computing Everyone!
[2025-12-02 00:09:44]
D.Vicious - Posts: 26
It’s been a while, but I tried several distros and ended up on Kubuntu, it was the only one that detected all 4 of my monitors off a 5060ti. I eventually rolled back to Windows, because I couldn’t get OpenGL working. Moving my charts around felt like 10FPS. Not sure if it’s even fixable/compatible, but has anyone gotten it to work? I'm guessing distro and WINE ver. Play a roll with it?
[2025-12-08 04:07:48]
User370774 - Posts: 35
How is the performance with wine by now?
I'm less thinking of graphical updates but market data and order submission/network stuff.
Are there still quirks, lags, interruptions?
Also I want to run it on a vps with ubuntu (thats fix) but within ubuntu I can do whatever I want, any experiences with wine in ubuntu?
Thank you in advance for your answers!
[2025-12-08 05:51:59]
Tony - Posts: 715
been using WINE since 2019, have never experienced anything close to "quirks, lags, interruptions"
I wouldn't trust any distros that are profit driven like ubuntu, I always use LMDE
[2025-12-08 06:11:10]
Well I have to use ubuntu (only option with that vps), but thank you for your feedback.
So market data and routing is the same latency as in windows? Did anybody use both and maybe even for scalping so there is experience of comparison?
[2026-01-03 15:22:34]
R1sk - Posts: 256
In my experience, the Bottles version downloads tick data faster. I believe this is because the Wine versions within Bottles are optimized for reduced network latency. This is why I use Bottles.
Date Time Of Last Edit: 2026-01-03 15:28:59
[2026-01-06 20:57:26]
Sierra_Chart Engineering - Posts: 23747
We want to update this thread that the Chat/Remote Alert functionality, now works properly in version 2855 on Wine/Linux:
Good News: Chat, Remote Alerts, Screen Sharing now Should Work on Linux/Wine/Mac/Crossover | Post: 433270
This lets you use remote alerts, which are also going to be upgraded soon with direct Google Firebase integration.
Date Time Of Last Edit: 2026-01-06 20:58:04
[2026-01-14 16:12:12]
Good to hear about 2855 and above working with wine/linux.
Just updated to wine 11, Mint 22.3 and SC 2862 and will be testing. There were a few non-wine window issues prior to 2862 but they have been resolved.
Oddly OpenGL is not working with Wine 11 and SC (blank screens for all charts).
Wine 10 worked without any OpenGL issues. Turning off OpenGL and restarting and everything is working now.
I have submitted a bug report
https://bugs.winehq.org/show_bug.cgi?id=59246
These newer versions of SC seem to be using much less memory and lower CPU utilization!
SierraChart Version 2862 64 bit (2 instances)
Wine 11.0
Mint Linux 22.3/Cinnamon desktop
Kernel 6.14.0-37 generic
AMD Ryzen 7 3800X
GeForce GTX 1660 Nvidia/6 GB GDDR5/Driver 580.95.05/OpenGL
Memory usage: <275 Meg for each instance..very low!
CPU Utilization: <3% for each instance..very low! Also, stable between CPU usage...equal CPU sharing.
Updated 1/14/26
Date Time Of Last Edit: 2026-01-14 22:14:43
[2026-01-14 20:09:18]
All users should be using version 2862 at this time if they are running a version, greater than 2813. Just making a note about that.
We will check on this:
[2026-01-14 20:52:37]
Sierra Chart - Max - Posts: 5928
@ertrader: Wine 11 uses the EGL backend by default for OpenGL, which may be incompatible with some older hardware.
I was able to get OpenGL to to work with an older Nvidia card by forcing the GLX backend:
Open the registry editor (on the terminal):
wine regedit
Go to the following Key:
HKEY_CURRENT_USER\Software\Wine\X11 Driver
Add a string value:
UseEGL
Set it to:
N
And then start Sierra Chart, and you should be able to see the chart while using OpenGL, just like they worked in previous versions of Wine.
Sierra Chart Support
Date Time Of Last Edit: 2026-01-14 21:20:55
[2026-01-14 21:32:17]
The OpenGL issues started with Wine > 10.10.
I opened the same bug report back in October. https://bugs.winehq.org/show_bug.cgi?id=58750
Haven't upgraded to Wine 11 yet, but even on Wine 10.18 on my new desktop, I have not had any issues with charts without OpenGL enabled like I had on my old laptop where I needed OpenGL enabled (Windows or Linux) for some of my charts to scroll properly.
[2026-01-14 21:51:09]
@Sierra Chart - Max
Brilliant...yes this worked.. thank you! I have updated the bug report.
Which is better to run under wine... OpenGL or without OpenGL?
Date Time Of Last Edit: 2026-01-14 21:53:29
[2026-01-14 22:02:40]
@ertrader If you have proper GPU driver support for the hardware used, then OpenGL is the way to go.
People running older AMD gpu's and apu's would have a better experience without OpenGL with Linux Kernel 6.18 and older, but with Kernel 6.19 and newer will have better results with OpenGL, because the newer kernel mainlined the modern Radion drivers.
[2026-01-14 22:11:39]
Very helpful..thank you!
@allons_trading.. appreciate that..yes looks exactly like the same issue. I had not seen it because I stayed on wine 10 stable till today.
Date Time Of Last Edit: 2026-01-14 22:17:42
[2026-03-09 12:47:40]
Updated CachyOS on my computer this weekend which included a Wine 11.3 update. Charts no longer loading up with OpenGL even with the UseEGL set to N. Downgraded back to Wine 11.2.
