Date/Time: Fri, 19 Apr 2024 13:14:45 +0000
Detached window's origin
View Count: 1340
[2013-09-05 00:29:52] |
TastyRisk - Posts: 119 |
If I have a few Detached Charts that are Always Visible, from various Chartbooks, how can I know from which Chartbook each Chart belongs ? Can I set the Chartbook name to be displayed in the window's titlebar? -perhaps there's another way to see the information that I haven't spotted ? Thanks. Date Time Of Last Edit: 2013-09-05 00:33:33
[2013-09-05 02:42:40] |
Right now, it is difficult to know which Chartbook these charts would belong to. However, you can set under Chart >> Chart Settings a custom title bar name. That should accomplish what you need. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-05 02:43:10
