Date/Time: Sat, 20 Apr 2024 10:12:23 +0000
Where do I install Transact AT (aka Sierra Charts) in order to use multiple datafeeds
View Count: 1350
[2013-09-04 07:16:04] |
sparky36 - Posts: 21 |
Hi Guys, Before today, I ran TransactAT and Sierra Charts together on the same machine which allowed me to pull barchart.com data thru Sierra Charts into my AT charts. For instance, my main AT chart is a 5m ES chart (using Transact data); on the subgraph below, I have NYSE Tick and NYSE up/dn vol (barchart.com data) pulled into my AT chart from Sierra Charts. After the forced upgrade from TransactAT, I no longer can do this. The new Transact upgrade only works when it is placed in a separate folder from Sierra Chart (ie. default Program Files (x86)) and not SierraChart/SierraChartTransActMA. Please don't tell me to ask Transact about this because they told me to contact SierraChart for a remedy. Thanks in advance for any and all help. |
[2013-09-04 17:46:40] |
If you do not already have Sierra Chart installed in your system, then download it here: http://www.sierrachart.com/index.php?l=doc/download.php Follow the instructions here to set it up to work with TransAct: http://www.sierrachart.com/index.php?l=doc/TransAct.php#SetupInstructions You do not need to use a separate data feed for NYSE Tick and NYSE up/dn vol. Use the integrated market statistics data feed: http://www.sierrachart.com/index.php?l=doc/helpdetails66.html Also, most likely the problem you are having with sharing data between copies of Sierra Chart has to do with one copy of Sierra Chart using Administrator access and another one not. Refer to this section here: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html#SharingWithAdminAccess Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-04 17:47:00
