Date/Time: Thu, 25 Apr 2024 23:08:43 +0000
Performance
View Count: 1645
[2013-09-03 11:13:12] |
Hendrixon - Posts: 130 |
1. About a year ago you agreed to add an option for us to change/set the interval of sc.UpdateAlways thru Acsil. 2. Can sc.OnExternalDataImmediateStudyCall be set on/off inside a study's body or only in the defaults stage? 3. Can you give access to "General Settings >> Chart Update Interval In Milliseconds" thru Acsil? ***** On all accounts it would be best if you'll allow setting them inside the study body, that way we can "throttle" the performance automatically based on market conditions. For example we could set sc.OnExternalDataImmediateStudyCall to be true only when we want to enter an order and/or change "Chart Update Interval In Milliseconds" to a low setting only if we have a live order etc. Date Time Of Last Edit: 2013-09-03 11:13:39
[2013-09-03 17:00:59] |
Fraois - Posts: 12 |
+1
[2013-09-04 04:14:49] |
1. We do not remember this. It is not something we can do now. 2. You can set that anywhere in the function and change its state at any time. There are code changes that we need to do to properly support this and this will be in the next release. 3. We will have to see about this. Eventually we do plan to make that setting controllable for individual charts instead of globally. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-04 11:28:06] |
1. Ok. can you please add it to the todo list? 2. Thanks. 3. "for individual charts" that will be great. it will cut down on the number of SC instances we need to run. |
[2013-09-23 02:27:56] |
1. We will only look into supporting setting the Chart Update Interval through ACSIL for the individual chart.
