Date/Time: Sat, 20 Apr 2024 03:30:37 +0000
ASX Stock codes/Data
View Count: 2906
[2013-09-03 17:32:44] |
We cannot help with Google. If you do not get data, then Google is not providing it. You can get ASX data through the Sierra Chart Historical Data service: https://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-03 17:33:19] |
Here is the symbol list: https://www.sierrachart.com/index.php?l=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks&ID=1#ASX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
