Date/Time: Thu, 25 Apr 2024 00:29:51 +0000
Unable to Build Custom Studies DLL
View Count: 3320
[2013-08-28 14:38:05] |
ganz - Posts: 1048 |
User95496 hi http://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html#stepbystep http://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html#UsingHeaderFiles gd lck |
[2013-08-28 15:13:01] |
User95496 add #include <windows.h> as explained here http://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html#UsingHeaderFiles Date Time Of Last Edit: 2013-08-28 15:13:19
[2013-08-28 17:04:48] |
We need to look into this and see why this is happening. Someone else reported this as well.
[2013-08-28 23:57:07] |
maxpi - Posts: 175 |
I had that same problem, adding the line to include windows.h does solve it. Moving to the Visual C++ environment also solves it.
[2013-08-29 00:38:12] |
This will definitely be solved in the next release of Sierra Chart.
[2013-08-29 00:47:27] |
We have this problem now resolved. We have now by default included the Windows.h header file. We were not previously because of the old Watcom compiler. However, the new compiler can easily handle this.
