Date/Time: Thu, 18 Apr 2024 17:09:07 +0000
Backtest Spreadsheet Trading System
View Count: 3796
[2013-08-28 00:54:36] |
4. This means you did not select the right symbol. You need to choose the symbol with [SIM] in front of it. If you want to experiment with back testing, use the trading systems referenced here: http://www.sierrachart.com/index.php?l=doc/doc_ACSILTrading.html#ExampleCode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
