Date/Time: Fri, 19 Apr 2024 07:12:35 +0000
Missing data?
View Count: 2399
[2013-04-03 17:11:56] |
Please refer to help topic 42.1 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails42.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-04 09:15:33] |
Re-download the data by going to the chart and selecting Edit >> Delete All Data and Download
[2013-04-09 15:52:33] |
User25778 - Posts: 4 |
I do not have this button in edit menu. I do not know what I have to do for this.
[2013-04-09 16:06:15] |
Please update by selecting Help >> Download Current Version.
[2013-04-09 16:25:23] |
I used perform symbol rollover and history is continual now. This is valid solotion? By the way What means Data storage unit (1 tick, 2 second etc.) thank you.
[2013-04-09 16:47:06] |
Are you referring to using the Continuous Futures Contract option in Chart >> Chart Settings? If so, that is a good solution. You can find documentation for Intraday Data Storage Time Unit here: http://www.sierrachart.com/index.php?l=doc/doc_DataSourceSettings.html#IntradayStorageUnit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-09 16:47:28
