Date/Time: Thu, 18 Apr 2024 23:35:28 +0000
Current Tool Config menu has grayed out options
View Count: 1828
[2013-08-14 16:40:05] |
QnReally - Posts: 181 |
Hello I am using v.1008 Pkg 5 and I was trying to choose "Config 2" under "Tools -> Current Tool Config" menu but that is grayed out. What am I doing wrong? http://screencast.com/t/4JIt70pef5 Thanks. |
[2013-08-14 16:58:45] |
This is because you need to first select a particular drawing tool other than Pointer. For example select Tools >>Line. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
